1937 hudson terraplane rat
Rear set up
I’ll post some pics tomorrow of the rear set up I’ve gone with . It’s a two link from a 60s truck instead of a triangulated 4 link .
Here it is the rear set up
Two link off a 60s truck made to fit a 37 hudson .
Next
Boxing plates fully welded in and tops of the mounts cut flush
Panhard bar
Decided to make a quick little pan hard bar today . It’s made out of 1 1/4 x .120 wall dom with heim joints and high angle spacers for the amount of travel this thing has .
Body back on
The body is back on , frame welded, motor mounts welded, trans mount welded , rear two link welded in , now on to the floor support and sheet metal .
Watts link
So the pan hard bar was bringing the rear end to far sideways when the car was put on the floor so I had to make a full custom watts link out of 3/16 plate and dom tubing and 2x2 1/4 square
Watts link
The second picture is the rear end fully up as far as it will go in the frame and it has very very minimal side to side movement .
Air bag mounts
So I made air bag brackets out of 3/16 plate and didn’t really get many pics besides this one that is them racked into place .
