Gearhead10
We got the 29 runnin and engine broke in a couple weeks ago. Havin a problem though. I can't get it timed right. I been around sbc engines all my life and this is the first time I've ever encountered this. I want to set it around 12 degrees as a startin point but It'll barely run. As I advance the dist it will smooth out but then the timing is way off the tab, like at 28-30 degrees. Now I've done all the checkin like: timing tab, harmonic balancer spun, TDC, we've moved the dist ahead and back a cog, etc. The dual point has a mechanical advance that is adjustable and I've already found out it was already adjusted wide open, which I've read is about 28 degrees. I now believe it should be 0. Put it back together and I can get it to run but still have a timing issue. I went to Mallory website and got alot of info but none seemed to help so far. For one thing I can't find the part # of my dist so I don't know if it is really old or what. There is a new Mallory Unilite unit in sight ,which I'm pushin for, but I would hate to spend that kinda money on a new distributor and still have the same problems. We are stuck to using a smaller dia dist because of the 3 duece setup. I guess the ? I have is am I missing something? Is the dist junk or am I just not gettin the right combination of adjustments. If I can get some info from some of you it would be cool. I just wanna know if this other dist is bad , just maladjusted or if I'm just goin crazy. Thanks
