Master cylinder for our '41 Pontiac
thom
Feb 25, 2009
132
western NC
I've mocked up a cylinder on our Pontiac. I'll probably use a smaller one though. I'll make the mounting bracket using the two holes where the original cylinder mounted, under the new cylinder in my pics. The pedal will clear on the engine side and the lines clear on the frame side. The pushrod will require a slight dogleg.
I've got the bracket made, just gotta finish welding, clean, and paint.
I now have an 80's Chevrolet truck (1/2 ton 2wd) rear axle assy to use, so as soon as I get it installed I'll rebuild all the brakes, including all new metal & rubber lines. The brakes will be finished.
