Go Back   Undead Sleds / Rat Rods Rule - Hot Rods, Rat Rods, Sleepers, Beaters & Bikes... since 2007! > Transmission, Rear End... Talk & Q&A!
Old 02-01-2016, 10:45 AM
Oldboy Oldboy is offline
Default Ford 8.8
Hello,
I just picked up a Ford 8.8 out of an 89 lincoln Lsc. Going to use in my next project. Disc brake, good ratio, inexpensive.
Question: should there be some play or runby in the differential? If i turn the pinion, im getting a bit of a "click" right now i am just cleaning this rear up, stripping it down, prep work. Looked at oil, its dark , but looks normal.
Thanks for weighing in
Russ
Old 02-01-2016, 09:30 PM
If it clicks when you rock the pinion back and forth, you have excessive backlash.
If it clicks when you rotate the differential... bearing(s).
Old 02-02-2016, 08:10 AM
Yankee Transplant's Avatar
Yankee Transplant Yankee Transplant is offline
He started out with nothing, he still has most of it!
Send a message via Yahoo to Yankee Transplant
Im thinking the same Dr.
Y.T.
Old 02-02-2016, 01:13 PM
Bamamav's Avatar
Bamamav Bamamav is offline
Or maybe a locker?
Old 02-02-2016, 11:01 PM
lowbudget50's Avatar
Mine has some sort of locker in it. Its a factory unit and it doesnt make any noise.
Minterfab.com
