Go Back   Undead Sleds / Rat Rods Rule - Hot Rods, Rat Rods, Sleepers, Beaters & Bikes... since 2007! > Engine Q&A!
Engine Q&A! The spot for engine talk, Q&A & tall tales!
Old 06-27-2021, 03:23 AM
23crate's Avatar
23crate 23crate is offline
Default Gm hei advance curve kit
hi all
is there any reason why i couldnt / shouldnt use a HEI advance curve kit on my elderly delco ?
thanks
When you are dead, it is only difficult for others.
when you are stupid its the same
the greatest victory is to live
Old 07-23-2021, 10:10 PM
the curve on the hei weights does not match the curve on the old point distributers.
just use the lightest springs you can find on the original weights, and try to get all the mechanical advance in by 3000rpm,
a low compression sbc will tolerate as much as 42 deg total timing at 3000rpm and above, if you have more than 10 to 1 compression limit total advance to 36 deg.
