Old 09-18-2021, 06:48 AM
DozerII's Avatar
DozerII DozerII is offline
Looking really good Torchie
Glen
Old 09-18-2021, 11:22 AM
Burgerman's Avatar
Burgerman Burgerman is offline
Agree. Keep those photos coming Torchie.
Old 09-18-2021, 11:57 AM
Neto Neto is offline
Just curious where you get your body-mount rubber biscuits. I've read a fair bit (on another forum) about the difficulty of finding quality rubber parts that don't go bad in just a few years. (I need to replace the rubber body to frame mounts on my 46 Plymouth. I reused the original ones when I put the body back on back in 80 or 81, and they're badly cracked now.)
Old 09-18-2021, 04:42 PM
Torchie's Avatar
Torchie Torchie is offline
Those are Hockey pucks, Neto.
Iíve been using them for years for body mounts. Trans mounts and even on engine mounts.
Easy to drill. They hold up well. They are inexpensive according to IRPOPS he even turns his on a lathe if he needs a different thickness or diameter.
Hope that helps you out.
Old 09-18-2021, 04:51 PM
Torchie's Avatar
I tied the side rails to the door sills.
Very solid .
Then I cut the next 2 cross pieces.
I will need a arch over the tail shaft and also one to clear the carrier bearing.
Got started on the first one and I ran out of welding gas.😳
That may be it for a few days. Going to be 80 here tomorrow then on Monday we head over to our daughters to make sure we are all on track for her wedding In October.
Thanks for checking up on me.....
Torchie.
Old 09-18-2021, 08:58 PM
Thanks, I remember now that you mentioned that in the past, but had forgotten.
Old 09-19-2021, 02:56 PM
Torchie's Avatar
Got more welding gas today.
Welded up the second arch.
The main floor section is set up with the two arches for the trans tunnel.
Rear of the second arch the floor can go flat with plenty of room for drive shaft up and down movement.
First time ever for me to sit in the car.
I'll let you guys make the vroom, vroom, noises.
Keep on keeping on....
Old 09-19-2021, 03:18 PM
dutch dutch is offline
it looks small with you in it...
Kewl, but small...
He who dies with the most toys wins
Old 09-19-2021, 04:30 PM
soltz's Avatar
soltz soltz is offline
The Rat Captain
Talking
VROOM VROOM
Be Safe
and
Be Creative
Old 09-19-2021, 04:49 PM
Yakitta yakitta yakitta
Copyright ©2000 - 2022, vBulletin Solutions, Inc.
