Old 01-24-2021, 12:15 PM
offroadrolls's Avatar
offroadrolls offroadrolls is offline
Default Power steering
I finished up the power steering yesterday. The used parts list for the power steering conversion are a pump and reservoir from a mid-eighties Toyota Mini Truck, steering gear from an early nineties Suzuki Sidekick / or Geo Tracker and a trans. cooler from a 1997 F350. The new parts are a couple of conversion kits, one to mount the steering gear,one to eliminate the rag joint and one to plumb everything together. The plumbing kit was a must have. It came with adapters for both the pump and the gear adapting them from whatever they were to 6-an. It also came with about 3 feet of bullet proof hose. I had to fabricate a bracket to mount the pump to the Volvo engine as well as spacers and such to come up with a double pulley system.
Hot things look just like Cold things
Offroadrolls build:
http://ratrodsrule.com/forum/showthread.php?t=23696
42 Chevy PU build:
http://ratrodsrule.com/forum/showthr...ht=42+chevy+pu
Old 01-24-2021, 01:58 PM
redidbull's Avatar
redidbull redidbull is offline
Originally Posted by offroadrolls View Post
I like that grill! Are the turn signals behind it? I have a plan for a grill on mine.
Thanks, yes they are behind the grill. Stock turn signals. Jim
Old 01-29-2021, 11:35 PM
Today I ran over to the parts house after failing at the hardware store in my hunt for a copper washer. Festus said sure we got a whole box of them and headed for the back room. Waiting for him to return to the counter, I pulled 3 bucks out of my pocket. When he returned we found the washer that worked the best on the fitting I brought along. He rung it up and said man they’re proud of that one, 6.39…………………I couldn’t do it. I replied to Festus, sorry man, I gotta draw the line somewhere. He agreed, I thanked him for his time and went back to work. Then I a found a drop of brass in Dales toolbox.
Offroadrolls build:
42 Chevy PU build:
Old 01-30-2021, 12:00 AM
MercuryMac's Avatar
Builder Junky!
I've had a tough time finding brass washers, over the years, also.
Keep on tinkering.
Old 01-30-2021, 04:50 AM
DozerII's Avatar
DozerII DozerII is offline
Nice job on the washer but I'm sure you only worked for $3.15 per hour.
Glen
Old 02-03-2021, 09:18 AM
LOL, that crossed my mind more than once, while I was sticking it to the man……….
For the return line from the heater core, Volvo used a tin water pipe with an o-ring on the end that is inserted into the water pump and secured by one of the water pump bolts. Then it turns the corner and runs along the side of the block under the exhaust manifold towards the firewall. I wanted to eliminate this pipe so I can just run a hose over the top of the engine from the hot water valve back to the water pump. Below is the nipple I made to do this, starting with a picture of the pipe it’ll replace.
Offroadrolls build:
42 Chevy PU build:
Old 02-03-2021, 06:41 PM
soltz's Avatar
soltz soltz is offline
The Rat Captain
Thumbs up
Nice job. You must be a machinist at heart I've had times I really wished I had a lath
Be Safe
and
Be Creative
Old 02-03-2021, 07:30 PM
Cool project.
Old 02-04-2021, 06:56 AM
redidbull's Avatar
I wish I did too. I keep looking but nothing in my price range ever pops up. Great work. Jim
Old 02-04-2021, 08:23 AM
At heart is right! The real machinist, Dale, has only been coming in a couple days a week for a few hours so, I've been having to do more lathe stuff on my own. Good thing I was paying attention the past 20 years as his apprentice. Usually I just hand him a print and the part magically appears. The possibilities are endless with a lathe.
Offroadrolls build:
42 Chevy PU build:
