Kasselyn29
- Joined
- Jan 13, 2011
- Messages
- 186
The "Jail Bar" Ford Lovers should be here soon to argue the point. But not to worry, they are a nice bunch otherwise.Started build on new truck like we need another one. Big truck front sheet metal so it's going to be ugly.
39 Ford truck headlights, I presume. The innards can be converted to standard seal beam bulbs with 67 or later VW Bug inserts. They are an almost perfect fit, and offer fine adjustment that the original didn't. There used to be aftermarket units made for early Ford bullets, but sadly they are no more.Thanks for the tips top hats looked like trouble already, opened up the adjustment slots, as far as head light a friend found me some from a 39 ford think they will work ok. Will try to keep updated work on truck is slow at best.
Nope. The early ones, with the glass covers, are much to complicated to fit in a bullet. The later ones are compact and will fit right in the can with little or no alteration. Down side is they are not cheap anymore.'67 or earlier, not later.
