1936-37 chevy trk help
Gus
Banned
Dec 9, 2011
1,107
Farmington NM
I need help with 1935/6/7/8 Chevy Trk
I'm ordering front glass and there is a difference in 1936 & 1937 Chevy truck apparently, I think it's only the high & low cab thing ???
36 had wood inside correct ?? and 37 they stopped using wood correct ??
mine had has no lumber inside ? Weather it was high or low to start I don't or didn't know ??
It don't matter tall cab or short cab if that's the only difference, because I chopped the top 2", it will save me from having a complete windshield cut. If you have a Filling Station catalogue look and see what you think. I think it's the high/low cab thing only...
I say and have said 37 low cab ??? wrong
To the best of my knowledge, '36 was a change over year so early trucks shared the tall cab of the '35s and the latter was the low cabs which ran until '38. I believe the 36s had some wood where the later years didnt.So a
36-38 glass should fit yours.
I was going to order it tonight online, but looking in the catalogue it throw me because there are different #'s and price for 1936 and 37 windshield ??
ws
yes there is diff...about 3/4"
not sure where you looked.
jim carter also lists two different ones
i have a 36 & 38 cabs and had two get diff ws frames
The Filling Station said 36 only had a piano hinge for the swing out 37-38 was a two hinge with a one piece rubber gasket as 36 basically only had left right and bottom gasket ???? ok I guess so ?? [S
My 36 low cab does not have a piano hinge.. Two hinges, the high cab would have the piano hinge... ...but as far as I understand the windshield heights do differ between a 36 low cab and 37-38 cabs ...
Other differences between 36 low cab and 37-38
- 36 had wood front door pillars that run up into the a pillars...
- 36 also had wood support behind the dash...
- the body line on the bottom of the cowl ... The 36 had a continuous body line where as the 37-38 has a partial line due to how the fenders arched across the cowl
