non marring steering wheel puller
I'm missing something here? [S Looks like the jack is just pulling the straps tight, but the jack is pressing against the wheel? [S Or do you have something under the block of wood pressing against the steering shaft? [S
the steering shaft nut is loosened almost all the way
so the wood is pushing on it
i soaked it with penetrating oild and put that thing on
every once in a while i would tighten it mnore
two days later i heard a noise that sounded like a cross between a bull whip and a gunshot
that thing had popped loose
if i hadnt put the shaft nut back on it would have taken out the rear window.
I have to hand it to ya, you are a patient man :)
I would have never thought of the jack idea [cl :cool:
i had a full plate
while my puller was doing its work
i was rewiring
and replacing every single rubber or plastic seal hose and gasket on that willys jeep
took me two years:rolleyes:
Isn't that something you would see in a Walmart parking lot, just go get the parts' wheel will be loose by the time you get home
My son made this for a stuck brake drum.
