Go Back   Undead Sleds / Rat Rods Rule - Hot Rods, Rat Rods, Sleepers, Beaters & Bikes... since 2007! > Tractors
Tractors Yes, we love old tractors too... let's see 'um!
Old 07-02-2020, 10:48 PM
offroadrolls's Avatar
offroadrolls offroadrolls is offline
Originally Posted by MercuryMac View Post
Is that a #10 or #11 and does it have a Jimmy or an Allis-Chalmers motor?
I'm not sure if it's a #10 or a #11. I was told it's the equivalent of a D8.
The engine says GM on it and it's bigger than 2 BBC's.
I put the plow truck battery that I used to get the Massey started in it today
and it turned over just fine. I don't want to try to start it until I pull the drain plug to see if there's water in the crank case (the oil is showing a couple quarts over full) Here's a picture of one that looks a lot like it but of course there's no way to reference size
Hot things look just like Cold things
Offroadrolls build:
http://ratrodsrule.com/forum/showthread.php?t=23696
42 Chevy PU build:
http://ratrodsrule.com/forum/showthr...ht=42+chevy+pu
Old 07-03-2020, 08:45 AM
Bamamav's Avatar
Bamamav Bamamav is offline
GM diesel would be a Detroit Diesel, a division of GM at that time I think. GMC had gas engines, not sure if they made a diesel?
If it's a Detroit, it's probably a 6-71, 318hp. Tough engine with factory installed oil leaks, lol. Two stroke, every stroke was a power stroke, and they slobbered oil. Old joke was if it quit leaking oil, it was fixing to blow up because it was dry.
2022 calendars available here:
https://www.zazzle.com/2022_fat_fend...46680814180838
Old 07-03-2020, 09:09 AM
That's a big beautiful pile of yellow
Old 07-03-2020, 12:20 PM
dutch dutch is offline
agreed....
Old 07-03-2020, 12:36 PM
MercuryMac's Avatar
MercuryMac MercuryMac is offline
Builder Junky!
Bama is right, GM motors have the nickname Jimmie.
You probably have the #16 like the picture. My brother is rebuilding a #10 and it's like an older D6 Cat. It will have a 4 cylinder GM in it when he gets it done.
Old 07-03-2020, 09:25 PM
phil cottingham phil cottingham is offline
Location: Fairhope, AL but originally from Centreville, AL.
Bama, I knew a guy years ago in Centreville that had a 56 GMC truck he pulled a lowboy to haul his HD16 dozier. The truck had what I thought was a GMC "Jimmie" diesel engine. If I remember right it was V6 with a big old blower on it.
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
