Front axle I should probably add. Man, I'm losing it. Got CRS, Can't remember s... tuff
Question is; Anyone have any information on converting the one ton front axle to disc brakes?
Motorhead - I assume your referring to a rear end? Since I have not taken it apart, I don't have a clue about the size of the spindle, but thinking out loud it may be very similar to a 1/2 ton.
32 - Have not measured the axle yet, but I would think it's not much wider than a pick up axle since the motor was built on a one ton chassis.
If I can convert this axle to disc with a five lug pattern, I will run a 9" Ford rear. Thought about trying to use 3/4 ton disc. I have seen how to swap a one ton rear over to disc.
Thanks,
