1989 F150 Slow Build
redidbull
RRR Supportor
Jan 13, 2018
926
South West CT
I have started building this 89 F150. I bought it for $700. It is a 302 with the overdrive tranny. The engine runs pretty good. So far I have replaced the plugs, cap, rotor, and wires. Also it had a drain on the battery and I found a bad alternator. I broke the alternator bracket trying to get the old one out but luckily ebay came through. I gutted the air pump because I am going to run long tube headers and true duals exiting in front of the wheel wells so it wont be used. The tires were horrible and undrivable. I happened upon 5 tires on rims for $125 on craigslist. The tranny slips but it has been sitting and it is leaking. I added some fluid and it was better. Best mod yet is the skull hood ornament!! Jim
    112.8 KB
    66.1 KB
    113.4 KB
    67.1 KB
    117.6 KB
    141.4 KB
    124.3 KB
Good old trucks, I had a 84 that I drove for 17 years.
I have a 5.0 that I put in my 47 Lincoln, I took the AIR pump off because it was locked up and reclocked the belt tensioner so I could run a shorter belt. Easy to do, just drill a hole in the mount for the pin on the tensioner to set it where you need it.
Weather kinda was nice for a change today so I was able to work on the 89F150 project. I decided to remove the exhaust manifolds for replacement with long tube headers. When I took off the the drivers side it was in 2 pieces. I don't think it is a good thing. Jim
    169.5 KB
    122.4 KB
