Since I'm not doing the welding, I gotta get this figured out 100% before hand. I don't want to have to deal with it again!
Well, after some more thought and research of some past threads, I'm going to go with 3x3 1/4 square tube for my rails. 3x2 3/16 is no where near the strength of 4x2 3/16, but 3x3 5/16 is close. That 1" less height will make a big difference for my plans.
The next problem I still have is how to deal with the rear Z. I'm very limited space-wise front to back. I have to cut the frame ahead of the lower link mount, but the rear passenger area is only 22" from the rear wheel center. So the less room the Z takes the better. My idea is to use steel plate. Is 1/2 steel plate strong enough? Bad idea? 3/4"?
This rear Z will depend on butt welding the frame to the rear side of the plate steel and butt welding the 3x3 rails to the front side. I can gusset some of it, but not really fishplate much. Will this be OK from a weld strength stand point?
