Golddredger
Active member
- Joined
- Dec 15, 2014
- Messages
- 44
I picked up this little car on 11/5/2014. It was a mess. Body is rough and not due to age but the previous owner butchered it. Cut it all up and cut holes for rear tires to fit in. The chop was bad. 1/2 difference in side to side no windows where the same and it tilted forward on one side over 3/4 of an inch. The body was all out of shape nothing even close to square. The first pictures show how it came home on the trailer. I got a model A frame and parts to go with it. The frame that was under the body when we loaded it was junk. made up of numerous old frames and hunks of metal. It actually broke the first 4ft section OFF on the way home just sitting on the trailer. Yes the frame cracked in half. No way I was using it. So I have been actually working on it for 4 weeks now. a few hours every night. I have built a new chassis from 2X3 .120 wall. Full four link rear with air bags. Just got the body on and mounted and all straightened out. Chopped it more and straightened it out side to side and front to back. Pick and pull had half price days at Thanksgiving so I picked up a turbo 350 tranny for it. I made a deal on a 1975 4 bolt main 350 with some old double hump heads a tunnel ram and a set of Holley carbs for a small block. The rear end is a GM 12 bolt. The tires are Firestone reps on 17" wheels. It is coming along pretty fast. next step is the front axle and motor tranny mounts. Need to hit the steal supply next week and get some more metal. The interior will be all Maple wood cut and fit to perfection. I own a portable bandsaw mill and I have a 200 year old maple tree I milled up and have some amazing wood from to use. The car will be named "Miss Maple" with a small pinup logo on the sides. I need to get a sheet of sheet metal as well and fill the wheel holes they cut in it back in. Enjoy the pictures.
