I've been searching other threads on rear 4-bar set-ups but really couldn't find what I was looking for. I'm planning on using short links that I can adjust from 12"-14" eye to eye so I can tuck the rear axle in closer to the body. I'll be using a transverse spring. My frame rails are 29" wide at the rear. If I mounted the bars to the outside of the rails and ran the bars straight back to the axle, would that distance between the mounts be OK? The rear axle is 56" backing plate to backing plate.
