chasinhiway
Active member
Well i decided to tackle installing a no limit engineering fat bar kit on my 54. there is something about completely removing the rearend and all that holds it in place that makes me a little nervous. But I just removed the volare front clip from my 54 and installed a mustang II under it and needed to get the rear end down to a more suitable level. The kit from no limit is very complete and the instructions are great and easy to follow with hand drawn illustrations. The first step is to remove the rear end leaf springs and all brackets. then locate the axle centerline (i did this before removing the axle) on some applications you may want to move were the wheel sets in the fender. From there its pretty straight forward measure the set distance from the centerline and thats where the front brackets go. adjust the bars to another set length and install them and the axle brackets. Then cent the rear end side to side and tack weld to brackets. From there just install upper and lower coil over brackets and panard bar. all brackets come with bolts to bolt to frame, I also welded mine.
