Rad Rob
I haven't had the chance to measure the WMS to determine if it's close to my '53 Poncho but I've got a friend with a '74 Ventura (NOVA) that's getting parted out. I need to replace or repair my front suspension because I've got a lower controll arm with rot so bad the coil popped out. So I thought this sub might make a good swap and give me updated brakes. It's got a running 250 Chevy six in it (looks to be Chevy trans pattern not BOP) and I can get the whole deal for about $400-$500. I've got a WC t-5 trans and a 3.73 posi rear out of an '83 camaro which I think would make that six come alive.
OR I can use the 305 I already have, bolt on an edelbrock intake, holley carb and the HEI dist. (I have those parts already) and throw that in the '74 sub. I think the '74 already has holes for V8 motor mounts and they SHOULD be chevy mounts because of the year of the car. I think I could get the sub for about $200 which is cheaper than trying to find the parts I need for my suspension and swapping to disk brakes, plus I'd gain power steering and I could use the Camaro steering column and the old school grant wheel I've been saving. Another bonus of that is I stole the wiring harness with fuse block from the camaro so I should be able to make the turn signal switch work AND the keyed ignition work in my '53.
I have the tools to swap in the sub and I'm confident in my welding ability but I'm still nervous about cutting my frame. I think it's worth the effort and I'm sure I can pull it off. I'm just thinking out loud because this is my first sub frame swap. I'm doing it only from what I've read in magazines and online so I need real advise.
