pushrod249
kinda stuck i'm trying to get my work truck ready for inspection and i need to replace the brake cables and cannot remove the drums. i released the pressure on the shoes. the drum seems to be pressed onto the axle shaft. the lug studs are pressed into the drum itself. axle is a stock ford unit in an '89 ford f- 150 4.9 6cyl 2wd 8' bed. any help is greatly appreciated as i am stuck here until i can fix this
