psychomike
- Joined
- May 11, 2008
- Messages
- 15
Hey Guys -
I am laying out the basic pieces to begin my build. It will be a 38 Chev truck - Chopped/channeled/Zframe. I will be building the frame and for the rear I plan on using a simple two point link (as opposed to four point) with a panhard rod. The bed will be shortened and narrowed and the only weight in back will be a fuel tank and battery.
Since I dont know what the actual weight will be and cant weight jack it until I'm done I was planning on putting in solid struts in place of coil-overs until I get it done, then determine the spring rate, and replace the struts with the coil-overs.
Then I was thinking I would use an old pair of air shocks I have so I can get the ride height dialed in while building it. My question is: can I just use air shocks without springs as a final means of suspending the vehicle? there will be very little travel in the back and very little weight so a nice set of coil-overs seems kind of a waste. Has anyone done this? Why should I NOT do this? Why is this different than Air Bags?
- Mike
- Mike
