Alignment Question-suicide cross steering
Burnout
May 31, 2007
89
Truckee, cA
I read on other posts that people are running 5-7 degress of caster and 0 degress of camber. What amount of toe in or toe out should I run?
Thanks
Scott
yeah what he said
I've always used 1/8" toe in.
1/8 inch to 3/16 inch toe in depending on tires.
6 to 9 on caster
straight up camber
just happens to be the older corvette spec's
you'll find that stright high speed stability is great and re-turn to center (after turns is very quick) makes for a great ride! dp1
