chopped 49
- Joined
- Jan 6, 2009
- Messages
- 5
Where are you guys running your caster with you I-beam axles?I know at zero deg the steering is real touchy.I am just not sure how far to lean the axle back before it wont turn? The truck had an IFS set up when I bought it so I don't know where they are set factory.Oh and I will be running the wheel base some where around 120-125" if the will affect the setting.
Thank you
Thank you
