Alternator
outlawz916
Active member
Feb 4, 2012
41
Will a GM three wire alternator charge a battery if the #1 field wire is connected to anything?? I've heard that if it isn't connected but if you rev your engine when you start up the engine it will start charging your battery and people claim they have ran their car like that for years without problems. Is this possible/true??
or can you run the #1 field wire to the battery post on the alternator if you put a diode in between them??
Ill add this it shows a little more.
    38.7 KB
