Magnum
I know most are doing the air ride thing, but I'm building an old school ( pre air bag ) rod... I've bumped up my frame 6 inches or so, so I can run the front roll pan at 4-5" off the ground, & still have 6-7" of wheel travel... I'm running a shorter mono spring up front, & have my traditional spring perch on the front of my springs, springs mounted under the I beam axle, & I'm building a bearing spring slider for better control, & a lower rear spring mount...
just curious if anyone else has incorporated one into their build ???
for those who aren't sure what a slider is, here's a link to a prefab unit... mine will be similar, but much more cleaned up & a bit heavier, since I plan to spank the rod once in a while...
http://www.speedwaymotors.com/Speedway-Heavy-Duty-Leaf-Spring-Sliders,5817.html
