phils
Looking closer at my axle, I thought I saw a twist in it. So I put my angle finder on 4 different points of the axle. The angle is all the same on both spring perch bosses and the driver's side king pin. But on the passenger side's kingpin it is like 2-4 degrees different (it sits forward).
The axle is a 1947 Ford that was dropped a total of 4".
I'm redoing my entire suspension right now (see other recent posts) and would like to know if I should have this fixed and how one goes about fixing/bending it so all 4 points are set correctly?
Or is this common & I should I not worry about it and just run it?
