Went to fire up the pressure washer today and about 5 minutes in, it took a dump. So while going through the preliminary inspection, the banjo bolt on the inlet snapped while removing it. @#$%##&(
So I went online and found the bolt at 3 different supply houses, the best price was 46.50 for a stupid banjo bolt. About that time Dale ask me if I'd found the bolt online. When I told him I had but for 46 bucks plus freight he replied "I'll just make one" So I figured what the heck, while he's doing that I can disassemble and clean the head assembly off the pressure washer, because from the looks of that banjo bolt there's clearly a chunk of something clogging a valve or something. Also I thought it'd be fun to document the "build" of a banjo bolt because this kind of thing fascinates me. Of course I'm easily entertained.
Start with a scrap of stainless
Setting the thread cutter in the tool holder
Cut da treads
Drill the hole
Finished in the lathe
Move to the mill and the indexing fixture to cut the hex
Drill the hole in the side.
Voila
Cut da treads
Drill the hole
Voila
