[[cl[dr:any body runnin a bat wing air cleaner,or rocket valve covers on a 350 in a 2dr coupe,does air cleaner clear everything,and does valve covers leak are you using the adapter for valve covers
I presume you are talking about a 350 Chevy. I have some Olds valve covers but I'm not using them. Just take a pair of factory steel SBC valve covers and weld studs to the top of those, then bolt the Olds valve covers over the sbc valve covers. They slip right ove the top of the sbc vavle vovers. I did the same thing to a pair of Lincoln valve covers but I'm not using those either. I collect valve covers and I was just goofing around with them for fun. They won't leak because the sbc valve cover is still bolted in place where it should be.
