ratphotog
Banned
I have my eye on my first rat rod project. It's a 1937 Ford Panel Van.
This thing is in decent shape, but it needs to be lowered and a drivetrain needs to be dropped in it.
It needs brake work and all that stuff of course so I was thinking about just transfering the body to an extended cab S-10 frame.
So I have some questions......
1. Should I just rebuild the 1937 brakes and replace all the brake lines and what not, then Z the frame?
2. Should I go forward with the S-10 swap idea?
3. What are your reasons for answering the first two questions the way you did?
4. Are brake and suspension parts for a 1937 Ford readily available at parts stores in an emergency?
5. Which way would be cheaper? S-10 or 37 rebuild?
The 1937 frame is solid enough to handle this build and if I use it I would still be removing the body to go through the frame and make sure everything is in good working order.
I want to build a reliable rat that I can put some serious miles on, but at the same time, I have a seriously tight budget. I just need to know which way I should proceed so I can establish a gameplan and a budget.
