marvels is not solvent. its low viscosity oil like shock oil with additives and silicon lubricant. It's considered a micro lubricant like liquid wrench or wd40 for it's ability to get into tight gaps.
marvels lubes valves and rings good and the silicon in it doesn't burn off the internals as easily as the mineral oil
I like to use it on engines which have been sitting a long time that could have some mild corrosion. It's resurrected a few mills that had rusty cylinder walls and sticky rings and valves.
Once I bought a 73 firebird with a 350 in it that was on the verge of being stuck. when it fired off a cloud of rust blew out the back
It ran through a couple fuel filters then was fine until I marveled the tank... ended up with 3 or 4 more fuel filters plugged with a fine rust powder before it stabilized
It always had that smell of burning antifreeze and caramelized mineral oil but it was an ever dependable champ and got me 22 mpg with a 2bbl and 2:41 gears and a turbo 350
Right before I retired the 350 she started puking antifreeze when she was cold.
I filled her back up with water and 6 eggs which sealed and cooked hard into the blown head gasket.
Drove it 2 more months like that without a problem. after earning enough for another car i let her sit a couple weeks and the egg seal went soft and failed
I went the 400... 1976 400 with 6s heads 800 cfm quadrajet and intake from a 455, and a 1969 RAIV cam
"RAIV cam= 0.516-inch lift 308-degrees intake/320-degrees exhaust, the cam's duration at 0.050-inch valve lift is what really set it apart. This cam came with an at-0.050-inch duration of 231-degrees intake and 240-degrees exhaust, which is almost impractically large even by modern roller-cam standards"
I had a 1973 grand prix with a 400, that RAIV cam, 2:73 posi, monte carlo handling package and weenie 235 75 r15's bfgoodrich all seasons that would beat any stock ho mustang I raced. Beat a guy with a datsun turbo Z several times and really got him flummoxed.
Never had it at the track for times but it would top out 50 mph in first, 85 mph in second and had it up around 120-130 a few times. it could have gone faster but I didn't want to push my luck on non speed rated tires
If you were cruising at 65 and dropped the hammer it would downshift flash up to the bottom of the power-band at 2200 rpm raise the nose and keep you slammed up to around 5,500 -6,000 rpm
I rant the same engine combo in that 73 bird but the 2:42 rear dragged it down off the line the first 50-60 feet. The firebird nailed would shift into second at 56mph, drive at 90 mph but I never top ended it
I was driving trucks at that time and didn't want to lose my job for racing
I never had an engine cammed up like that before
When first got the car I couldn't figure out why I couldn't get it to run smooth with just a carb and ignition rebuild.
The vacuum advance in the dizzy was siezed from sitting so I swapped that out and it still wouldn't run worth a damn (so I thought) until the first time I hit 2200 rpm and all hell broke luce
hell broke luce
http://www.youtube.com/watch?v=0Fju9o8BVJ8
I later put a 400 in. the 350 had a whistle on one cylinder from a bad headgasket crossfiring
Drove it like that a year
When I tore it down you could rock the piston tops about .020 the cylinders were so worn
I bought an 86 f600 in denver put a hitch on it and bought a tow dolly in fort morgan at american tow dolly and towed my pickup home.
I bought 1 qt marvels. put half in the oil half in the gas.
before I got back to Omaha The rain was beading off my pickup from the silicon in the exhaust fumes from the marvels burning off
I don't know what it would do to an oxygen sensor. might mess it up
I got that bird at a really tough time in my life and it got me through. It had headers, burnt out glass packs and pipes that kicked out at the rear of the doors
I miss that reassuring "blub blub blub blub blub blub blub fwoooo- blub blub blub blub blub blub blub fwooo"
