Brake/Clutch pedal travel
icebox
Feb 24, 2011
242
tip of the mitt
I mounted a brake/clutch master cylinder under the dash of my 1950 ford f-1. I built the bracket to hold the master cylinder and also built the pivots for the pedals.I am using the original bell housing and replacement clutch slave cylinder . I am trying to figure out the pedals now. My question is how much pedal swing do i need ?
[/URL][/IMG]
The way I did mine was figure master cyl plunger travel,then measure pedal travel, then from the pivot point move down until you get the stroke you need.
