brake line bracket and t fittings
tmontanez
May 28, 2012
57
California
hello,
I am looking for the brakets that you weld to the differential and the one's you weld up front for the brake lines. i found these online, they are bolt on or weld on.
https://www.circletracksupply.com/Brake-Line-Bracket-Bolt-On-or-Weld-On.-L-Bracket.html
Also heard you could go get a piece of metal from the hardware store and drill the hole and weld that....save money
also I found these t fittings online for the brake lines, would any t fittings fit a 64 chevelle, if so i'll just go to the junk yard
thanks
We have those for a $1.00 each. We also have the little tab that you weld to the frame, or rear end housing, that folds over and holds the brake line in place.
