brake switch
Witc one do you have ,got a pic?not sure what you want but,
You can hook it up either way to check it out ,wont hert anything ,it will be either ''on'' or ''off'' .
The small arm on the switch is spring loaded and is always in the on position. You mount it so that when you release the brakes the brake pedal hits the small arm on the switch and pushes it to the off position. If your brake pedal is swing mounted you would mount the switch at about the same location as the stock switch on GM cars. If your brake pedal is floor mounted you would mount the switch under the floor or firewall so that when you take your foot off the brake the pedal hits the small arm and turns the brake lites off. Wire it from the fuse box to either side of the switch and run a wire from the other post to the brake lite, or thru the turn sigs if you have them.:)
Here is a pcture of how mine's mounted.
[/QUOTE]
thankful
sure am thankful (once again) for this site and all of you guys ....
i would have done the whole lever thing COMPLETELY backwards
as far as on/off goes ... sure wish i had a hangin brake pedal --
mounting on the backside of the floorpan/firewall was not fun lol
