Charley Davidson
Went to do rear brakes and ran into major issues, now need whole rear end.
Couldn't get the passenger side rear brake drum off so I checked where the leak was and tightened the brake line and it stopped, checked fluid in m/c bone dry filled it pumped pedal but no brakes, m/c empty again, the drivers side wheel cylinder blew, started, took off wheel and drum was split in half from the brake shoe wearing it too thin.
now the real issue, can't get the drums off and they are a weird set up, not sure if it's the right rear end or not, one guy says yes another says no.
Ever see a setup like this? The differential number is 741 last 3 #s
