Yep, we have them on two cars. First off, the 90 fin are the later ones, I think the 45's were from '57 to '61 maybe. Ours are '59's with 45 fins. I think they look more oldtimey than the 90 fins ones, but I also think they are the same installationwise.
To do the job you need two good drums (hold onto your wallet, they are fetching big money now for good, usable ones) and two early Ford front hubs. If memory serves me correctly, you need the hubs from like 1946-48. They are the ones where the flange on the hub is on the OUTSIDE of the original Ford drum. (Some were made with a hub that removed from the INSIDE of the drum, you do not want these)
You will press out the studs and remove the hubs and machine them on a lathe so that they just slip into the empty Buick drums (by empty I mean the Buick hubs have been removed by drilling out the rivits) Once you get that fit, you drill new holes through the Ford pattern and through the Buick drums so that you can install new, long studs from the back. That is the OLD way to do them.
Recently, Wilson Welding has developed brand new Ford type hubs for this swap, and they are already made to size, and feature a steel ring that goes inside to weld your studs to. They sell a little arbor to drill the holes in the exact spot for like $ 5.00 or so, BUY IT. I didn't know it existed, and a local machine shop ripped me off for something like $ 175 to drill 10 lug bolt holes.
With the arbor you can do it yourself on any drill press.
Here is the site for Wilson Welding. Best people around and great products too. I have posted a couple of pictures of my set of Buick drums, and also the ones on my Kids '29. He is also using their finned backing plates which are a work of art, and feature late model self energizing brakes.
www.wilsonweldingandmachine.com/
BTW, if anyone tells you '40 Ford brakes with Buick drums won't stop your rod.................that is BS. I had a set on my '27 for 7 years of day in day out driving, and it stopped like ABS braking. And on my new T I made some very fast stops the other night while doing my burnout routine and it stopped straight and fast. These things rock on a lightweight car.
