Chain steering
blacksheep
Jul 7, 2010
956
Ludowici, GA
Have any of you guys set up a rod with chain steering? If so, got any photos of your set up? I plan on doing this to the bucket , mainly because of some clearance issues I may have. I was thinking if set up with triple sprockets with solid set bolt type tensioner that it could be made and still be safe. I am wanting to run my steeing shaft almost paralell to the floor under the cowl using the chain outside the cowl. Any thoughts?
Speedway sells something like that. Xpensive though.
Theres some modern cars like the Chevy Malibu that do a 'fly by wire' steering where they dont have a steering shaft--just wires --that'd be interesting.. (especially if ya blow a fuse)
They also do a gas pedal that way too.. (Toyotas have a sale on those)
It all sounds 'outta the box' and dangerous doesn't it? :D
Even the chain drive sounds iffy. How about a cowl steering thing where the arm is on the side of the car? At least it'd be a straight direct hook up.
PA41
PA41
Yes, I thought about cowl steering. I'm using a Vega steering box, and would have to study it for a while. I think with a #50 chain 3 wide with set bolt sprocket tensioner it would be very safe. I know they sell them, but I think one could be fabbed fairly easily using insustrial sprockets and good oring chain.
Like this?
Two row chain is plenty strong,used on lots of farm equipment with high torque engines,so steering on a light car should be no problem. TSC also known as Tractor Supply Company has all that stuff.I would defenitly use two bearings a couple inches apart on each shaft for stability.
Oh yes, Tractor Supply is my hang out here. There's one about 30 miles away from where I live. I'll post some photos when I get to that point.
I would put a plate with bearings on the other side of the sprockets too. And the bigger the sprockets, the less lost motion you will have.
I plan on using 4 seperate bearings all one bracket .One inside and one outside the firewall. I;ll make it so that I can adjust the tension from the front with locking nuts on it for secuirty.
