52 fordman
I got these numbers off the front of the engine by the water pump.
130210084 10713HN
I was told it was a 68 327. But after doing some work i dont know. The truck is a 66 C10 Chevy 1/2 ton 2wd. I put a set of headers on and ended up cutting the frame/ motor mounts. The plugs are real close to the tubes and the starter is about 1/4 inch from one of the tubes. I put an edlebrock manifold and that was fine as i knew it would be.
Headers are flowtech not the most expensive set but i am on a cheap budget.
Any one have any ideas or thoughts? Any one know the numbers and what motor it really is?
52 fordman
130210084 10713HN
52 fordman
