I'm wanting to switch my rear radius rods with clevis's for a 4-bar set-up and retain the single mounting bracket on the axle. My question is, could I bolt up a heim to one side of the existing bracket without fear of failure or shearing to the bracket? The other end of the bar will be mounted through the 2x3 frame rail. The bracket on the axle is 3/8" thick and I would be using a 5/8" bolt.
I may be over analyzing things but I was just thinking how a clevis is mounted which is centered on the bracket and a heim in my case would be mounted to one side of the bracket. Anyone have any input on this?
