Willowbilly3
A *real* tin magnet
I have seen the extension for the pitman shaft made by using a tube welded to the splined part of the old pitman arm, then put the nut on inside the tube. Seems to be the simplest method but I am wondering how much you guys feel would be the maximum amount of extension you could safely do with this method?
