cowl steering
The BMW box is a natural. It is from mid '70's I think and came on model 2002 cars. If my Son shoots me some pictures of the one he was using I will post them.
Ok, my Kid got me a couple of shots of his when he was going to use the BMW box. Here goes...............not very good pictures, but all he has. BTW, the arm points down and the shaft is long enough to center the steering wheel on you when you are driving, and yet extend outside the cowl.
    32.6 KB
    36.5 KB
It would be nice to have a thread with the dimensions for various boxes,
for cowl steering.
Specifically,the amount of offset,left to right,from the input shaft
to the pitman arm,and the length of the stock pitman arm.
Makes more sense to find the "right" box,
instead of trying to modify the "wrong" box.
Tried to get one going on the HAMB,might have the mopar dimensions there.
Somewhere.
Mopar box
I have a mopar box I am going to use. I will get some measurements and pics and post later tonight.
mopar box for cowl steering
looking at the box from the way it would be mounted itis 6 3/4" from the center of the steering shaft to the center of the pitman arm.100_1120 (Medium).jpg
the aluminum housing is 8 3/4" wide x 71/2" deep x 71/2" tall.100_1122 (Medium).jpg
The pitman arm is 51/4" center to center(too short). I saw where someone had cut the round splined piece off the pitman arm then tigged it inside a piece of DOM tubing to extend outside of cowl then made a new pitman arm the correct length.
Hope this helps a little. when i get mine done i will post pics but it will be about a month or so.
this is what I'm going to do also
Here's a few pics of the box i have.View attachment 12111
looking at the box from the way it would be mounted itis 6 3/4" from the center of the steering shaft to the center of the pitman arm.View attachment 12112
the aluminum housing is 8 3/4" wide x 71/2" deep x 71/2" tall.View attachment 12113
Here's one I'm working on now. The tube that is welded to the pitman arm has a large enough hole for the nut and a socket to fit inside.
The steering box is from a Toyota FJ. An eBay purchase for about $40. In my case, it is bolted to a drilled and tapped plate that will be welded to the top of the frame. It could be mounted higher on a hoop for a more traditional cowl steering location. In this installation the steering box will be under the floor footboard and inside the firewall so it won't show at all.
The pitman is made out of 3/8" thick plate that I cut with an angle grinder with a cut off wheel. The big holes are made with a hole saw. I borrowed the correct reamer to taper the holes for the tie rod end. The splined end of the Toyota pitman arm was cut off and ground fairly round and welded into the thick wall tubing used to extend the pitman arm through the cowl. If I was to do a cowl steering mounted higher I would prefer the Mopar steering box other guys have shown. But, I had this one that I bought for a different project and didn't use. Nothing goes to waste around my shop. The drag link is 7/8' dia DOM with a .156" wall, drilled and tapped for 11/16" NF thread.
