Degreaser........
martyf
Nov 30, 2011
183
Stonewall, LA
WOOTCHA USE??
Im about to start cleaning up a 454/T400 I pulled out of an RV, as well I have a 9" I need to clean up so I can do some moding,
What do you you use to clean up and degrease oily greasy piece parts or frames, or what ever, (dogs, daughters boyfriends,)
I use a combination of things. I scrape the thick stuff I can get at. I also like the oven cleaner and then the pressure washer. A lot of small parts just get washed in a basin with parts solvent and a brush, then a quick spray off with B-12 Carb clean or Brakleen. I used to take engine castings to the machine shop and have them hot tanked and I still take gas tanks and such to the radiator shop to have boiled out.
