Denso Mini ?????
Great little alternator,If yer runnin much electrics ,amp may B to lo though.
Works great in my roadsters.
    107.5 KB
    98 KB
thanks guys. The only major accessory I will be running is an electric fuel pump. I'll give one a try.
Gastrick, you also answered another question I had. I wanted to use the high alt. mount. Would it fit between the oil filler tube and valve cover. Looks like it will.
c-dog,
Both my cars have electric pumps and the Anglia also has an electric fan. The high mount on the the Anglia just barely leaves room for the alt. without much room for adjustment. You have to get the belt length just right unless you mount it a bit higher.
This picture shows the mounting bracket I made a little better. I also used a breather cap from a flathead Ford because it's smaller and clears my adjustment arm better although I could have just made a different adjustment arm. I still may do that some day..
