Dimensions of Mustang II control arms
Mutt's37Buick
Jun 27, 2011
201
Westminster, CO
Can anyone provide some dimesnions for a set of stock or tubular Mustang II upper and lower control arms?
These would be the A-shaped lower control arm (no-strut design).
I would hope to use a strut rod in addition for added strength.
It's a long shot, but I'm exploring the option of using them with my Buick cross member and springs.
If you can furnish dimensions A, B, & C for a lower arm, that would help.
If you can furnish diemensions A & C for and upper arm, that would help.
See the attached sketch.
Thanks for your help.
    15.1 KB
I am in the process of installing a MII kit with tubular arms on a 54 GMC for a guy. I will try to get some measurements off the control arms here pretty soon. PM me if I forget and don't get to it within a couple days... I'm easily distracted, LOL.
Okay, here's what I came up with:
A= 7 3/8"
B= 8 1/2"
C= 12 7/8" (approx)
Not sure what you mean on bolt center to center.
The bushings where the control arm attaches to the chassis are 1 7/8" long.
Also, the ball joint is not centered fore to aft, it is offset to one side. I didn't measure this dimension. If the other dimensions work for you, I can try to get an accurate measurement for you on this.
