disk brake rear end
hoagie
Apr 13, 2013
10
Guys I need your help. I can get a rear end for my rat project but it has disk brakes. Will I be able to use it with my drum brake front end? Please any help
Hoagie
Well, it's kinda the opposite of what's normal but I'd think you could just use a disc/drum master and route the disc side to the rear, drum side to the front. You would definitely need to use an adjustable proportioning valve on the line to the rear discs as they are almost certain to be more powerful than the front drums, then you can tune them down to prevent locking up.
    195 KB
I have a F6 front axle and I have not seen anything for a F6 I also want to keep the big wheels 19.5
From what I have found F1-F3 is the same, and after that the spindles are different. I'm not sure there is enough demand for the larger trucks for a company to provide a kit, but it would be worth a call to one of them to find out.
