pistolpete
Been researching a bit on a few other sites. Just wondering if anyone on here has came up with their own take on this. I know there is a way to do it, without forking $300 on a kit. I want to run a T5 tranny behind a flathead so this is what is driving the thought process.
Quick run down of what I am thinking
- cut torque tube
- make a cap with an opening for the seal & weld to cut torque tube
- take the coupling out of the torque tube, and weld it to a yoke
- turn the weld down on a lathe to make sure it isnt unbalanced & possibly change the OD on the seal end to make work with an off the shelf oil seal (if needed)
The one thing I am slightly hung up on is how to keep the yoke on the splines. I have seen them just drilled and through bolted, but that looks like it would really be unbalanced to me... was thinking maybe a shear pin, or a machine screw or something like that... Still in the thinking stages on this so any wisdom would be appreciated.
- cut torque tube
