Carlos Murphy
Is there a drain plug in a 9" Ford diff.?
Now, if you are talking about the FILL plug, Ford made two rear axle housings. One had a fill plug on the back and one did not. If you have the one with no fill plug you MUST use a center section (pumpkin, hogs head, whatever you like to call em ) that has a fill plug in the side of it. More than once someone has used a housing with no fill plug and a center section with no fill plug and after it is bolted together they discover there is no way to put gear lube in the housing.
