Drums
E$rnie Pintor III
Dec 14, 2011
149
Southern california
Ok, here it is... I have a 50 f-1. Rear end is a 93 f150 . Got a new aftermarket master cylinder from a sand rail shop. Gonna use pedal from a 61 ford truck.... Could I just put a t after master cylinder and cap off the front ones and just hook up to rear? How safe is that?
Not safe at all. Your front brake are the ones that do most the stopping. With rears only the back end will want to slide on you. Go out and use just your emergency brake on a car and see what happens.
I would just spend the money on the right master and the residual valves for the rear. MPBrakes sells MC setups for the F1 for Disc/Disc Drum/Disc, and Drum/Drum setups...
