ECI brakes
24dodge
One of the Dodge brothers
May 18, 2007
1,103
Jupiter Florida
This is what I worked on today , installed an ECI disc brake kit on the `32 chevy axle , really nice kit , went together like it was supposed to, only problem I had was the spindles stuck out of the hub to far for me to use the stock dust caps , made some aluminum ones that worked out well.
    73.5 KB
    73.8 KB
Looks good 24, I've had good luck with ECI in the past. Motomech here on the board has the same problem with the spindles protruding too far on his front brakes. He was looking for a solution. Maybe your thread will help him out. Did you make your dust caps on a lathe?
Ya , the kit comes with a warning that you have to check the tie rod often because of the increase in braking force tends to bend them , i`m going to sleeve mine with some DOM tubing to be safe.
