440shorty
I posted this in my build thread in the Builds section, but I thought that maybe it would get more views here. I know that it sounds odd, but I have quite a few engines and am trying to decide what engine to put into my project. Keep in mind that there will be no hood or fenders to hide the engine, so it will be out in the open for all to see. I want to use a 5-speed, but all I have are NWC T-5 transmissions, which puts a limit on the torque I can put through it. I'd like to use an odd-ball engine, but one that has respectable power. Also, the total weight should be around 2000 pounds, so it won't take a lot of power for it to be fun to drive. No matter what engine I choose, I have a 3.90 geared O rear that will even turn the weakest engine into somewhat of a hero, and overdrive will make it streetable.
Here are my current engine options ( I can post pics later of some of them) in no particular order:
(1) '66 Buick 340 V8 - only built for 2 years, looks different than later Buick V8s. It's a 2-bbl engine ( 9:1 compression) but I have a 4-bbl intake and the parts to put it together. I'd need to get a stick flywheel, though. Looks bigger than it is - has a tall deck.
(2) 403 Olds (or maybe a 350 Olds) - I have most of the parts - hot cam, fresh heads, Performer RPM intake, etc. but the 403 short block is worn out (kinda usable) or I'd have to mix 'n' match parts + buy rings & bearings to piece together a 350 short block.
(3) Cadillac 4100 V8, FWD version - very odd ball, but small displacement (250 cubes) - it is a GM reman, ran when pulled. Aluminum block, iron heads. Would have people guessing, but rated at 150 HP stock, with few aftermarket parts available. Easy conversion to carb + HEI though. T5 5 speed can mate to it - I have the bellhousing.
(4) All aluminum Olds V8 - another small-cube powerplant - the heads are off mine, so I'd have to buy parts to at least reassemble it; disadvantage is that it has a weird bellhousing pattern, and I only have the baby Slim-Jim auto for it.
(5) Taurus SHO V6 - we have the complete engine and harness, but would need to scrounge up a Ranger 5-speed and some parts to make it work. 220 HP, wild looking, for sure.
(6) I can get a running '89 EFI 3.8 Buick (FWD) V6 with harness and ECU, and I have a factory supercharger setup off a '93. Would take some work, but would definitely be different.
What do you all think??
440shorty
P.S. It would figure that I have the smallest displacement Cad engine ever made.
440shorty
