BigIrish
The Fairlane I just bought has a rebuilt 289, stock exhaust manifolds. When it gets fully warmed up there is a noticable tick from the engine under load. It sounds like a lifter tick, but only when you give it some gas and only when hot. Let off the gas an coast...no tick. Rev the engine in neutral, no tick.
It seems like the only thing it could be is a exh manifold gasket leak, but I can't see any evidence of it. Maybe cracked manifold? If it was a mechanical tick, then I think it would make the noise regardless of load...right? I checked the lifters (non-adjustable) and they are all tight with no slop.
Any other ideas? Only other thing that crossed my mind is that one cylinder is detonating due to incorrect heat range on a sparkplug or something. [S
