Ever seen one of these
Edge of sanity
Active member
May 30, 2015
29
I repeat ever seen one of these?
It opens up steering thought.
It is off a Isuzu like a Rodeo.
The steering shaft comes out of dash
to this little box in front of the rack which is in front
and then it has a hookup back to the rack.
    46.1 KB
I believe it is.
But not sure. Don't have one in hand.
But I bought a 2002 rodeo for the frame even
though it is a nice SUV. Four used transmissions and my
niece gave up on it and called me wanting to borrow my dolly
to take it to junkyard. So after looking it over, wide frame,
coils in rear, and this curious steering I bought it.
Decided to put a S10 transmission in it from 2.8 engine when
I realized engine bolt pattern, u-joints, convertor bolt pattern
(used 1/2 nut spacers) was the same as the Chevy. Even had a
a Mustang driveshaft the right length.
It has a electronic throttle so had to go through dash and pull throttle
and add piece to it . The dash had a plugged hole same as the
S10 throttle cable .
Went in pretty well without making much. It is a two wheel drive.
I' ll try and mark and check even though the housing looks like
the gears inside would be same size.
